Brilliant, no default mailbox
After all my bitching over the last couple of days, I should like to comment on how good it is that F9 decided that we account holders should be able to decide for ourselves whether we want mail delivered to the default mail address. I have blocked the default address on all 3 of my accounts and I have received a 100% reduction in spam to non mailbox accounts Smiley . No more jkjfmfhfcg@username.f9.co.uk filling up my webmail and taking an eternity to load.
May I suggest that if you have not already done so, set it up straight away and reap the benefits.
Cheers
Mark
lhorwath
Hi Mark,
It was because of the customer opinion that this was needed, that we implemented this feature. We have certainly had very positive feedback from customer who are not active in the forums and I've found it useful as well Smiley
regards
Luke
antdav
Cheesy
Well done F9/PlusNet!
..., it appears that you do listen to all our gripes then!
sjkirky
Sorry if I'm being completely ignorant, but how do you go about setting this up?
jberry
Just raise a ticket but follow the correct path through the wizard:
Technical :: E-mail :: I want to have mail sent to my default (Catch-all) mailbox blocked / deleted
sjkirky
Ah! Danke schön...
