Brilliant Feature
Brilliant Feature
I have just come across the feature on the portal that shows you haow much of your web space you have used and how much is left, both in megabits and as a percentage.
A wonderful feature.
I have had a look to see if there is the same for my CGI space but cannot find anything. Does it exist for the CGI space and if not can it be implemented for a future update of the portal?
It would be very useful here as with things like guest books etc wich keep growing located in the CGI space and only the 50 meg to play with the space could be exeeded without realising.
Regards
http://www.hmrg.co.uk
RE: Brilliant Feature
I'll discuss this internally to see if we can get it on the portal. As an aside, if you want to know how much CGI space you have used, you will be able to log in via SSH/Telnet and type
du -h .
This will tell you how much space you have used in the current directory.
Regards,
Mike
| Mike Grice....................Unmetered & ADSL solutions
| Technical Support.....................for Home & Business
| PlusNet Technologies Ltd.........@ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
> Hi there,
> du -h .
> Regards,
> Mike
Thanks for that Mike.
I don't think I am anywhere near the limit but I will check by using the above command.
Regards
Not a problem - I find myself using it a lot :-)
Regards,
Mike
