Brasque 3day bits:
Brasque 3day bits:
OK, Theres a lot of uncertanty going on here about the 3 day buisness, so does any one know bassed on this: when brasque should update:?
Modem Status
Connection Status Connected
Us Rate (Kbps) 448
Ds Rate (Kbps) 8128
US Margin 26
DS Margin 16
Trained Modulation GDMT
LOS Errors 0
DS Line Attenuation 24
US Line Attenuation 9
Peak Cell Rate 1056 cells per sec
CRC Rx Fast 30
CRC Tx Fast 9
CRC Rx Interleaved 0
CRC Tx Interleaved 0
Path Mode Fast Path
Connected 72hr 31min 58sec N/A
Should i restart the router? or will that make me wait anouther 3 days as sugested some where?
1 REPLY
Fixes: 8
Brasque 3day bits:
Reconnecting won't do any harm - and could do some good. However looking at your stats I don't think you will sync at a different speed - unless you've got a dodgy filter handy.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
