Best Wireless Router
Hallo.
I need to purchase a new Wireless router, as my partner's Wanadoo livebox thing seems as though it wont work on any other ISP apart from Wanadoo/Orange.
I've been reading around, and the Netger DG834G I think appears to be the best.
My requirements are
1. Something that will work well on ADSLMax (in the future of course) - My line synchs at around 3400kbps.
2. Two computers will be connected, both using USB Wireless adapters, so this shouldnt be a problem. Distances are not too bad either
3. I'll be needing pretty good security, WEP/WPA etc - I assume the Netgear model i've mentioned will be enough
If anyone has any better suggestions please let me know
Re: Best Wireless Router
See http://www.agp.dsl.pipex.com/inventel.html for an item called Unlocking the Livebox, I put "wanadoo livebox hacking" into google and this was what I found.
I guess once it is unlocked, your could then reconfigure the Voip settings which would be neat. The DG834G does not have built in Voip support/sockets like the Livebox.
SW.
3Mb FTTC
SW.
Superb. You've just saved me £70.
