BUG: Postmaster alias edit
Although I had already set up a redirect for my postmaster address, I thought I'd try the new 'edit postmaster alias' feature that has recently been added.
However, after changing the target to a different mailbox, I now have two postmaster aliases listed :roll:
A) the original pointing to the one mailbox
B) the new alias pointing to a different mailbox
Clearly there is a bug in the code, I'm not sure which of the two aliases (if either) is actually valid, but can someone please fix this? :?
Plusnet Staff
Plusnet Staff
Fixes: 159
If you want to PM me with the mailbox you want the postmaster pointing to I'll get this raised and sorted out for you.
 Chris Parr
 Plusnet Staff
thanks for your reply Chris, PM sent Wink
I just wanted you guys to be aware that there seemed to be a bug in the script for that page Wink
Plusnet Staff
Plusnet Staff
Fixes: 159
Yep cheers, I'm keeping an eye out for any other reports of this.
 Chris Parr
 Plusnet Staff
