BT speedtester error
I've been trying every speed test going to see what they say about this pitiful excuse of a connection I have currently, and upon using http://www.speedtester.bt.com/ I get this message:
System Error
The IP address discovered on the network associated with your telephone number:0208xxxxxxx, did not match the one we have logged from this browser/connection. Please check your telephone number and try again. If problem persists please contact your ISP.
My number is in correct, so is this something PN could look into?
passer
It's a bug.I get it sometimes, but eventually I get through.
shellsong
If I remember right that tester quite often does that-- you just have to persist until it works
It's more something BT need to look into! :roll:
James
The new speedtester is a right pain. It is *really* helpful in giving you some additional information, but at least the old one near enough always worked.
Re: BT speedtester error
Something may be up because I too repeatedly got that error this morning, previously I have never had this error ... just lots of others about the System Too Busy
SW.
3Mb FTTC
James
Anyone getting this error message? I'll ask Sarah to raise it with BT if it is a common issue.
Fixes: 8
I've just tried it and for the first time ever, it worked at the first attempt.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
James
*falls off chair*
Had that error message many times James...usually takes 2 or 3 more attempts for it to work.
*falls off chair*
Did anyone get a screen grap of the webcam?
Chilly Tongue
James
Nope, I'm in hiding Smiley Mand, Dave and I have a little corner on the CSC floor, although this is apparently subject to change so that we are more involved with the rest of the CSC and seen to be more easily approachable.
sophos9
I get this error amounts several different ones, keep retrying and it works fine...
Fixes: 8
As the comms team are the ones we have most contact with, would it not be appropriate to have a specific Comms team webcam?
James
Not if we're going to be moving desk soon Smiley
Plus I would object Cheesy
So would I, have you *seen* James?
You'll notice the img is linked so you can see who the picture really is. :lol:
