BT speed test
BT speed test
We're looking for discrepancies between these two links:
http://speedtester.bt.com
I'm trying to run the BT speed test but when it comes to entering my user name I get this:
TEST ERROR
The login name entered on this tool doesnt match that discovered by querying the network for your domain name. Please check your telephone number (or user name) and try again.
I used my user name for these portals, is that correct?
Re: BT speed test
You need to put your username@plusdsl.net or whatever you use.
[Moderator's note by James - (sallyandjames): Full quote of preceding post removed as per the link:rules]
BT speed test
That is one of the various error messages you get when the machine is overloaded. I only ever find the speedtester works before 8am, after that it is problematic.
SW.
3Mb FTTC
Re: BT speed test
Ah, I see. Stupidly I was using <theattic@plus.com>!
Thanks for that.
I got these results back:
TEST RESULTS
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 4000 kbps
DSL connection rate: 448 kbps(UP-STREAM) 4608 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 3708 kbps
If you wish to discuss these results please contact your ISP.
If you are experiencing problems with specific applications, servers or websites please contact your ISP for assistance.
Your test has completed please close this window to exit the performance tester.
They seem ok but then what do I know... Wink
Edit:
Thanks for the tip. I'll try it again tomorrow.
BT speed test
anytime mate Smiley
James
BT speed test
Yep - That's your connection performing as expected as per the profiling at their end. Ther profile you have assigned at our end is suitable per the bRAS restriction.
