BT speed test results?
aeroalfie
Is there something wrong with my connection - here are BT speed test results.
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 3500 kbps
DSL connection rate: 448kbps(UP-STREAM)4608kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 1300kbps
exchange is showing as Green.
1 REPLY
Plusnet Staff
Plusnet Staff
With one speedtest result it's tough to say if there's anything wrong. The IP Profile is about right for the sync speed, if it stays sync'd at that speed it should go up to 4000kbps in a few days.
The throughput is within BT's guidelines for a Max service and may not be low enough for the exchange to show as red. I'd suspect that the off peak speeds will show higher than this, probably around or just over 3Mbps.
