BT engineers :(
BT engineers :(
After having a very unstable connection since I was 'upgraded' to maxdsl back in may I finally submitted a support ticket about a month ago and finally today after all the usual back and forth to see if the problem is with my equipment etc a BT engineer did some work on my line to increase the SNR as it wasn't doing it automatically.
Unfortunately the engineer seems to have decided that I would be better off as a BT broadband customer as i now connect with a BTcentralplus.com IP address (using my plusnet log in details) which means I am now completely without internet access (I am using a neighbours internet to write this.
I don't really want to wait another week for customer support to get around to reading my ticket again so if any plusnet staff reads this can you please take a look at my ticket and see if you can do something about it. The ticket is ID: 19874813.
Cheers
FYI>
I think you are having this problem because of the ongoing issues @ telehouse north.
if you can't authenticated against your ISP's servers you will get given a BT IP and when you try to browse you will see a BT page saying something is stuffed.
BT engineers :(
It seems you were right. Connection is back up again now. Because the connection problem occured at the same time as the BT engineer had done work on my line I assumed they were related but it must've just been bad timing.
timps
BT engineers :(
hi moratarian
please see my posts today's date.. i'm on the littleborough exchange too sorry they were mean't as replies to this post
timps
