BT Activation
BT Activation
Can anybody tell me if there is anyway of checking that Bt have activated my line for Adsl apart from the usual line going dead for one hour and when you dial the engineers test number. As I think my line was activated two days ago but not a word from plusnet as yet.
Thanks Coley
RE: BT Activation
Good Evening,
There is indeed if you set you equipment up as per the settings on the portal :-
VPI = 0
VCI = 38
PPPoA VC mux based Rfc 2364
G.Dmt
And then for the user/password :-
startup_user@startup_domain
Password field should be left blank.
if you can connect on this and bring up the page :-
www.bt.net /digitaldemo then your adsl account is active and you should contact us and relay this information and ask for your account to be activated.
Regards,
| Lee Mckenzie....................Unmetered & ADSL solutions
| Technical Support......................for Home & Business
| PlusNet Technologies Ltd.............@ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet ----- +
RE: BT Activation
> You see thats the problem you have my modem and wont let me have it till my line is activated so really I should of put how to tell without a modem.
RE: BT Activation
Hi Guy,
Unfortunately there is no way that you can check for line activation without having some ADSL hardware, and our starterpacks are not dispatched until we get confirmation from BT about the activation.
Regards
Josh
| Josh Berry.......................Unmetered & ADSL solutions
| Technical Support.......................for Home & Business
| PlusNet Technologies Ltd.............@http://www.plus.net
