BT Activation Progress?
ayster
Does BT have somewhere where you can check the progress of the ADSL activation? Just curious as to how far along they are with my line!
Cheers.
RE: BT Activation Progress?
> Cheers.
You can actually check this on our site by clicking the My Connection link and then selecting ADSL Tracker.
Kind Regards,
Rob
| Robert Kelly.....................Unmetered & ADSL solutions
| Technical Support...................for Home & Business
| PlusNet Technologies Ltd...........@ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
ayster
> > Cheers.
> Hi,
Yep, thanks, I check that daily!, but all it says is My order has been sent to BT for further testing and activation, it doesn't show their actual progress.
Cheers.
fonejacker
Hi There,
Unfortunately this is as much feedback as we get from BT. As soon as they tell us that they have done the work on your exchange, your account will automatically move to the activated stage.
Regards,
Ian Wild
PlusNet Customer Support
