BBYW regrade and ADSL+ upgrade?
dhumble
I have just moved from Premier 1 to BBYW 3 and was just wondering if you get automatically upgraded to ADSL+ or, do I still need to raise a ticket?
Plusnet Staff
Plusnet Staff
Fixes: 159
Normally this will be requested at the time of changing product, however it appears that one of my colleagues made the change manually for you which may have been the reason for the upgrade not going through.
I'll go make sure this happens early next week for you.
 Chris Parr
 Plusnet Staff
dhumble
Many thanks Chris, appreciated. Can you point me to a link for any changes I have to make? I have a Draytek 2800V and wonder if I will need to change modulation from G.DMT to ADSL2(G992.3)?
Plusnet Staff
Plusnet Staff
Fixes: 159
Your router settings should be able to remain unchanged.
 Chris Parr
 Plusnet Staff
dhumble
Many thanks Chris and I appreciate PN's staff commitment during the bad weather conditions you're experiencing.
From Sun burnt David in Milton Keynes. When the sun does come out, boy is it strong!
