BBC Multicast
JonathanW
BBC Multicast
Well, with any luck we'll be able to get things moving again and you can get on the trial. Though I'd not hold your breath too much, especially with this warm weather that we're having at the moment.
BBC Multicast
Hi All,
I have just come accross http://www.bbc.co.uk/multicast/ and was wondering if there was any reason that we on force9 arent able to use it.
Plusnet is listed in the isp listings and I was under the impression that f9 is pretty much governed by plusnet or is just another feature we cant get on f9?
any one have any luck with it. seems quite interesting to me.
JonathanW
BBC Multicast
You should be able to take part in the trial, though previously it's been a case of having to get your account enabled for it, and we've had to put the next stages of the project on hold for a little while whilst we evalute the situation.
I'd suggest keeping an eye on this page over at PUG as it'll be updated once more information is available.
BBC Multicast
Hi Jon,
Thanks for the reply thats cleared up most things. Too bad I missed the chance to be on the trail.
Ant.
