Awful Sync problems today...
Has anyone else had severe problems getting line sync today, I think since 9am this morning, i've had about 2 hours of a solid connection, the rest of the time, my modem just goes into training mode, am I the only one?
Pick up your phone and listen, dial a single digit to remove the dial tone ... is it noisey?
If so contact BT and report a 'voice fault'.
If not, any unusal environmental things happened today ... lots of rain? Sad
SW.
3Mb FTTC
It's really strange you suggest that, because my line just went off again, unplugged the phone to put in the dialup modem line, sync is back, unplug modem line to plug phone back in, sync is lost...can an actual phone cause loss of line sync, I didn't think this was possible!
craign
did you get your problems sorted in early April? You posted line figures of
Noise Margin - +22.0 dB Up / Between +6.1 & +7.5 dB Down
Attenuation - +31.5dB Up / +62.4dB Down
which are on the limit - esp the downstream attentuation.
Is it raining / windy / stormy with you at the moment? It's been wet and blowy in Suffolk. I woke to 2.5dB downstream - cured by a router adsl line reset, well I say cured... back up to its new maxDSL norm of 6.5.
They're as sorted as PN problems ever get sorted, i've got connection about 90% of the time, lose sync at least once every 2 days for a few hours at a time
Do not get MaxDSl on this line ... Sad
Yes, a phone can have an affect just being plugged in, mine did this until I fitted a filtered faceplate to my master socket.
SW.
3Mb FTTC
I've already ticketed PN to opt out of MaxDSL...does this mean i'm automatically moved to LLU?
Fixes: 8
1. Is the phone filtered? (i.e. not using a splitter or plugged in to an unfiltered extension)
2. Is it a cordless phone?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
yup...microfiltered as it should be and plugged into the master socket, I get no sync at all if plugged into the main faceplate....it's a corded phone.
