Automatic BCC or CC with webmail
itchyfeet
When I'm not at home, I use the webmail facility to send e-mail. which I find very useful. The only problem I have is that I like to keep a copy of all the e-mail I have sent.
The solution I use for this is to send a copy of the e-mail (usually as a BCC) to a separate mailbox "sentmail@...plus.com" which I can then pick up with my e-mail program at home.
Would it be possible to have the option on webmail to always send a copy of the e-mail to a particular address, so that I wouldn't have to type this in every time.
(Alternatively, are there any other ways of solving this problem?)
1 REPLY
JonathanW
If you log into webmail via the IMAP option, it should automatically save a copy of the message to a folder for you, which can then be accessed at a later date, either through webmail or through the imap.plus.net server in your email client.
