Auto-login problem
Auto-login problem
I've been having a few problems with auto-login recently (it appears to be switched on but when I go directly to VMBU or the discussion forums I'm sometimes asked to login).
It's struck me that this may be because I access the portal from two PCs (home and office). If I login to the account on one PC, does it effectively disable auto-login on the other?
Thanks!
JonathanW
Auto-login problem
Yes, if you log into the portal from a different PC or browser, then it will effectively disable auto-login that you've got set on your main PC.
Auto-login problem
Thanks Jon, that explains it.
