Auto Login Help!!!
Auto Login Help!!!
Hi All,
Why the heck cant I get auto login to work on my XP Pro SP2 machine. I have turned off my spyware software (Spybot) and turned off IE's cookie blocker. It works fine in W2K but not on XP.
Any advice would be much appreciated.
Cheers
Jon
Auto Login Help!!!
Are you trying to use it on more than one machine? I think due to security issues it was changed to work on one machine, but I could be wrong.
Failing that, clear out your cookies and try re-enabling it.
Auto Login Help!!!
Yep that worked thanks. I actually backed up and removed my cookies. Then set up the auto login, tested it and then restored my original cookies. Some cookies are actually useful and didnt want to remove them all.
Cheers
Jon
