Astraweb ping
Astraweb ping
Is anyone else getting a shocking ping from Astraweb? My latency is almost 3 seconds.
Pinging pbdl.news.astraweb.com [216.151.153.47] with 32 bytes of data:
Reply from 216.151.153.47: bytes=32 time=2853ms TTL=49
Reply from 216.151.153.47: bytes=32 time=2704ms TTL=49
Reply from 216.151.153.47: bytes=32 time=2522ms TTL=49
Reply from 216.151.153.47: bytes=32 time=2706ms TTL=49
Should I blame Astraweb or plusnet?
Astraweb ping
Never head of it before but just did a ping and got 4 request timed out. Make of that what you will.
Astraweb ping
Sorry, I didn't mention what it is. It's a USENET server.
Novocastrian
Astraweb ping
Haven't a clue what it all means, but here's what I got using the tool at http://www.dnsstuff.com/
Pinging pbdl.news.astraweb.com [216.151.153.22]:
Ping #1: Got reply from 216.151.153.22 in 43ms [TTL=54]
Ping #2: Got reply from 216.151.153.22 in 43ms [TTL=54]
Ping #3: Got reply from 216.151.153.22 in 42ms [TTL=54]
Ping #4: Got reply from 216.151.153.22 in 44ms [TTL=54]
Variation: 1.3ms (+/- 3%)
Shortest Time: 42ms
Average: 43ms
Longest Time: 44ms
Done pinging pbdl.news.astraweb.com!
It's probably relevent that I am on PAYG
Astraweb ping
Well the tool at dnsstuff isn't doing it through the plusnet network. What happens if YOU do it in a cmd box?
Start -> Run -> Type "cmd" -> Type "ping pbdl.news...."
Zathras
Astraweb ping
I get 250ms...Im payg.
Astraweb ping
You lucky this is what i get
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
ping pbdl.news.astraweb.com
Pinging pbdl.news.astraweb.com [216.151.153.45] with 32 bytes of data:
Request timed out.
Reply from 216.151.153.45: bytes=32 time=2835ms TTL=49
Reply from 216.151.153.45: bytes=32 time=2460ms TTL=49
Reply from 216.151.153.45: bytes=32 time=2674ms TTL=49
Ping statistics for 216.151.153.45:
Packets: Sent = 4, Received = 3, Lost = 1 (25% loss),
Approximate round trip times in milli-seconds:
Minimum = 2460ms, Maximum = 2835ms, Average = 2656ms
been the same for the last couple of days at any time except for a few hours in the early hours (gmt)
Even at 7am this morning my dl speeds from astraweb were crawling at about 10kbps compared to the ~500kbps i was getting off peak a week or so back...
The torrent i am dl'ing at the mo (22 seeds and 45 peers) is crawling at 5.5kbps, im used to seeing around 40-50kbps....
Every thing including text newsgroup access is crap at the mo, you can prove this by posting via your news server EG: astraweb and then doing the same via google groups, the astraweb post takes an age to show up and reading other posts is painfully slow, posting and reading via google groups is still fine..........I have also verified this with other dedicated usenet servers (other than astraweb) and get the same result Evil
Novocastrian
Astraweb ping
ok, through command box
Pinging pbdl.news.astraweb.com [216.151.153.14] with 32 bytes of data:
Reply from 216.151.153.14: bytes=32 time=289ms TTL=49
Reply from 216.151.153.14: bytes=32 time=275ms TTL=49
Reply from 216.151.153.14: bytes=32 time=273ms TTL=49
Reply from 216.151.153.14: bytes=32 time=281ms TTL=49
Ping statistics for 216.151.153.14:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Minimum = 273ms, Maximum = 289ms, Average = 279ms
Astraweb ping
A tracert shows the congestion at the final hop. Perhaps Astraweb's network is shagged?
Zathras
Astraweb ping
@op Im betting then youre on premier?
Astraweb ping
Yeah I am. Why?
Zathras
Astraweb ping
Usenet is in the lowest priority for premier.
Astraweb ping
Yeah, but a ping is not USENET traffic.
Zathras
Astraweb ping
Maybe its just coincidence then.
Astraweb ping
Are plusnet up to something here?
Here's a ping log for Giganews (same latency):
Pinging news.giganews.com [216.196.109.131] with 32 bytes of data:
Reply from 216.196.109.131: bytes=32 time=2580ms TTL=115
Reply from 216.196.109.131: bytes=32 time=2485ms TTL=115
Reply from 216.196.109.131: bytes=32 time=2677ms TTL=115
Reply from 216.196.109.131: bytes=32 time=2884ms TTL=115
But here's another log done via BT broadband:
Reply from 216.196.109.131: bytes=32 time=88ms TTL=94
Reply from 216.196.109.131: bytes=32 time=89ms TTL=94
Reply from 216.196.109.131: bytes=32 time=71ms TTL=94
The ping to Astraweb over BT broadband is 200ish.
