Arrggh, Help Please.... to Email, or not to email
Hi, call me thick, but what does the following message mean:-
"There was a problem logging onto your mail server. Your Password was rejected. Account: 'mail.plus.net', Server: 'mail.plus.net', Protocol: POP3, Server Response: '-ERR Login failed.', Port: 110, Secure(SSL): No, Server Error: 0x800CCC90, Error Number: 0x800CCC92"
... apart from the obvious fact that I can't access email??
Sad
cheers,
Steve
ah.. thats it then
Oops apologies, just noticed the thread re. dodgy POP3 connections, or rather, non-connections.
I shall just have to be patient and watch the thunderstorms... until tomorrow.
Thanks,
Steve. Shockedops:
Plusnet Staff
Plusnet Staff
Hi Steve,
The error means that you were unable to log in to your mailbox. We have had a problem regarding this today, take a look at service status, it should be fixed by 1am.
If you want to double check that this is the cause then try webmail, if that fails to log in as well, then give it go tomorrow and it should be fine.
ah.. thats it then
Thanks,
Steve. Shockedops:
