Are PN restricting speed at peak times...
Ok its just past 4pm and my speeds have dropped again to a LOW of 769...Surely 7 minutes past the 4pm mark there wouldnt be that many more people online.......
mine seems fine today
http://www.speedtest.bbmax.co.uk/results.php?t=1147879465&v=47068
i can't complain about that speed at peak time
tomorrow, it may be a different story
Your very lucky...I have never had those speeds(during off peak or peak) and my router says 8128 down and 448 up and PN stable page says 7000...Most I have had was around 3000 and that was about 3am
JJ
All the school kids are back home !!
Getting 3.5Mbps at the moment. 6.5Mbps off peak
JohnH
aeroalfie
715+KB/s down
46.5KB/s up
Cheesy
If you speed takes a drastic nose dive as soon as you hit peak time it sounds like you might have gone over your monthly usage allowance?
I am getting half decent speeds myself at the moment but it's not even the real peak hours yet' Let's see what happens between 6pm and 10pm. In my expierences over the last week or so on MAx DSL the speeds usually drop by about 50%.
http://www.speedtest.bbmax.co.uk/results.php?t=1147880854&v=47125
4.8Mbps(600K/sec) downloading
715+KB/s down
46.5KB/s up
Cheesy
Dont think so 1.2gb peak time..Now that isnt over my limit is it..Unless of course they have changed that again
What does a BT speedtest show?
Traffic is prioritised 24*7, PN make no secret of that but just how much of it is downto this prioritisation can only be highlighted by BT speedtests from your end.
Fixes: 8
What results are you getting when connecting direct to BT and running their speed test?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Seem to be ok tonight just done a test and i got this
http://www.speedtest.bbmax.co.uk/results.php?t=1147882004&v=47176
JJ
antrobus6 Is having real problems. Please see his other posts.
It would make it easier for us to help you if you kept to one thread otherwise we will just repeat ourselves.
JohnH
Well I'm getting horrendous speeds tonight. But that's probably due to my exchange having no bandwidth Sad Curses to living in Southampton! Cheesy
I have found a good site to check your exchange in real time.... Just enter your number
http://www.prodigynet.co.uk/menu.php?page=support/adsllinecheck
One of the many things you find out when you have problems...Never needed to before Max I suppose..
JohnH
Thanks mate.....
Couger
well then what the hell is going on just got this result
http://www.speedtest.bbmax.co.uk/results.php?t=1147887812&v=47699
yet that real time exchange checker reveals that Available bandwidth (Mbps) 100-110 on each DSLAMS in my exchange,
and theres 4 DSLAMS in my exchange
So.....
If theres bandwidth free
Why the result from the speed test HuhHuhHuhHuh?
