Anyone moved to a new ISP and gotten a better connection?
Specifically, did PN tell you that Maxdsl would decide what speed you should have and it would be the same with any other provider?
If they did and you still moved, did you get an improvement or were PN correct?
I'm seriously tempted to leave. I figure that it can't be any worse if PN are right but it may actually be better.
shellsong
Not many people can answer "from the other side" since they lose the ability to post on the main forums unless they have an extant account-- maybe you'd be better off asking on the thinkbroadband forums!
Hi Moved to keconnect,
on plusnet i was getting speeds around .5 with keconnect im seeing speeds on downloads around 3-4.
I was on a primer accound with no restirctions.
Liam
