Anyone know about this problem
Over the last couple of weeks i am getting problems staying connected to the internet, it just seems to go down for no reason, i know its nothing to do with my pc as when internet goes off i cant connect through my pda either.
I suppose it could be something to do with my Belkin Modem/router but it just comes on as mysteriously as it goes off.
JonathanW
When you loose the connection, does the sync light on your router start to flash at all?
As you've said that this is affecting a couple of different devices, its possibly either down to your router, or down to the line itself.
When i go into the router (192.168.2.1) i have to keep clicking on "connect" i am not sure if its just coinsidence but after about 15-20 minuts it connects.
No matey the lights on the modem/router dont change, it shows all is working ok.
pda is not going through pc it has direct connect to the Rourer/modem wirelessly.
