Anyone having problems running skype?
nicecuppa
Hi there
Is anyone having problems using skype? I've got a computer more than capable of running it, but the conversations are very choppy and often break up. It hasn't changed over weeks. Its really annoying after being upgraded to max, I thought I'd have no problems. It ran fine when I was on 2meg.
Dave
Phil_Collins
I don't use Skype but I do use other Voip applications I did experience some problems a while ago but since reserving bandbwidth for voip in my router settings I have since had no problems
ady
nope runs fine over here, and even when i was on a 512 bras profile :O
nicecuppa
Phil, what router do you have and how did you reserve bandbwidth for voip in your router settings?
Thanks both for your replies.
