Anyone else having really bad problems tonight
Our current speeds are the following:
17-02-2006 18:40:11 617.6
17-02-2006 18:36:26 418.1
17-02-2006 18:32:07 675.6
17-02-2006 17:57:49 672.4
BT speedtest also gives very low speeds!!!
Why can nothing just go nice and simple.
Unfortunately if the BT test is showing slow speeds then the problem most likely lies with your exchange.
Enter your phone number into the Exchange Checker and see if there any reported problems.
I should advise that BT are not the quickest at updating that information, so it may not show an issue.
If BT's test is also slow I'd put it down to contention at the exchange, have you checked you're exhange status?
Unfortunately I don't think that Plusnet will do anything until they can raise a fault, which means speeds would have to be much lower than those you've reported Sad
Yep checked exchange and all seems well, will just have to ride out this storm.
Cannot help but feel that asking for MAC key today was a bad move.
Cheers
Asking for your mac will have no bearing on what happens at your exchange.
However if you have been given your MAC, you dont have to use it. It will just expire if not used within 30 days.
Hi
Its just the time of the day its a free for all atm to many people not enough bandwidth
17-02-2006 18:49:01 1247.8
17-02-2006 18:48:28 910.6
17-02-2006 18:48:02 691.1
17-02-2006 09:51:11 1951.4
16-02-2006 08:25:06 1934.7
Hi Mark
Given all the problems we are having with low and throttled speeds (Business user) this will be the first thing we do tomorrow is to find a new provider.
Is just such a shame PN use to be a name you were proud to say was your ISP and I hope someday they will regain there reputation.
um if BT speed tester is slow engnet, then a new provider wont help at all.
If however your seeing poor speeds when the speed tester is fine then thats a different matter.
