Anyone else having problems with Steam?
Its been a while since I played Half Life 2, so I tried to have a go but for the past week or so I've been unable to connect to Steam. All the settings are correct my end and they suggest it couold be the ISP - is anyone else having difficulties connecting?
Fixes: 57
No problem here.
Just connected to Steam and got a load of Steam updates.
Needed to reconfigure Firewall access as its preferred option is to block it.
It updated a while there fore the exe changes so your firewall maybe blocking it in the background but you can't see the popup asking if its ok to allow it because you have HL2 fullscreen. This was what happened to a friend of mine. I'm probably totally wrong but hey I tried Cheesy
My steam is working fine btw, just tried it.
Midville
Fine here too........but I keep getting killed on HL2 Sad
Hmm I have the same problem Cheesy
