Anyone else having authentication problems?
I am! Sad
I'd come back in June or July if I were you - someone at PlusNet may have replied in a useful manner by then :-(
You could always raise a ticket or phone the support line........... not that it will do you any good of course, but it may make you feel a tiny bit better......
now u say this yes, i thought it was my router....
0|Source:192.168.0.2 login System Up Time Fri, 4/28/2006 22:19:43
1|PPP : PPP Connection OK Fri, 4/28/2006 19:41:46
2|PPP : IPCP OK Fri, 4/28/2006 19:41:46
3|PPP : IPCP Start Fri, 4/28/2006 19:41:46
4|PPP : CHAP OK Fri, 4/28/2006 19:41:46
5|PPP : CHAP Recv Challenge Fri, 4/28/2006 19:41:45
6|PPP : CHAP Start Fri, 4/28/2006 19:41:45
7|PPP : LCP OK Fri, 4/28/2006 19:41:45
8|PPP : LCP Start Fri, 4/28/2006 19:41:45
9|PPP : PPP Start Fri, 4/28/2006 19:41:45
10|PPP : PPP Disconnect Fri, 4/28/2006 19:41:45
11|PPP : PPP Idle Timeout Fri, 4/28/2006 19:41:45
12|PPP : LCP Start Fri, 4/28/2006 19:41:44
13|PPP : PPP Start Fri, 4/28/2006 19:41:44
14|PPP : PPP Disconnect Fri, 4/28/2006 19:41:43
15|PPP : PPP Idle Timeout Fri, 4/28/2006 19:41:43
16|PPP : LCP Start Fri, 4/28/2006 19:41:42
17|PPP : PPP Start Fri, 4/28/2006 19:41:42
18|PPP : CHAP Recv Challenge Fri, 4/28/2006 19:41:42
19|PPP : CHAP Start Fri, 4/28/2006 19:41:42
20|PPP : LCP OK Fri, 4/28/2006 19:41:42
21|PPP : LCP Start Fri, 4/28/2006 19:41:42
22|PPP : PPP Start Fri, 4/28/2006 19:41:42
23|PPP : PPP Disconnect Fri, 4/28/2006 19:41:41
24|PPP : PPP Idle Timeout Fri, 4/28/2006 19:41:41
25|PPP : LCP Start Fri, 4/28/2006 19:41:39
26|PPP : PPP Start Fri, 4/28/2006 19:41:39
27|PPP : PPP Disconnect Fri, 4/28/2006 19:41:39
28|PPP : PPP Idle Timeout Fri, 4/28/2006 19:41:39
29|PPP : LCP Start Fri, 4/28/2006 19:41:37
30|PPP : PPP Start Fri, 4/28/2006 19:41:37
31|PPP : PPP Disconnect Fri, 4/28/2006 19:41:37
32|PPP : PPP Idle Timeout Fri, 4/28/2006 19:41:37
33|PPP : LCP Start Fri, 4/28/2006 19:41:35
34|PPP : PPP Start Fri, 4/28/2006 19:41:35
35|PPP : PPP Disconnect Fri, 4/28/2006 19:41:35
36|PPP : PPP Idle Timeout Fri, 4/28/2006 19:41:35
37|PPP : PPP Connection OK Fri, 4/28/2006 11:11:32
38|PPP : IPCP OK Fri, 4/28/2006 11:11:32
39|PPP : IPCP Start Fri, 4/28/2006 11:11:32
40|PPP : CHAP OK Fri, 4/28/2006 11:11:32
41|PPP : CHAP Recv Challenge Fri, 4/28/2006 11:11:32
42|PPP : CHAP Start Fri, 4/28/2006 11:11:32
43|PPP : LCP OK Fri, 4/28/2006 11:11:32
44|PPP : LCP Start Fri, 4/28/2006 11:11:31
45|PPP : PPP Start Fri, 4/28/2006 11:11:31
46|PPP : PPP Disconnect Fri, 4/28/2006 11:11:31
47|PPP : PPP Idle Timeout Fri, 4/28/2006 11:11:31
48|PPP : LCP Start Fri, 4/28/2006 11:11:29
49|PPP : PPP Start Fri, 4/28/2006 11:11:29
50|PPP : PPP Disconnect Fri, 4/28/2006 11:11:29
51|PPP : PPP Idle Timeout Fri, 4/28/2006 11:11:29
52|PPP : LCP Start Fri, 4/28/2006 11:11:29
53|PPP : PPP Start Fri, 4/28/2006 11:11:29
54|PPP : CHAP Recv Challenge Fri, 4/28/2006 11:11:28
55|PPP : CHAP Start Fri, 4/28/2006 11:11:28
56|PPP : LCP OK Fri, 4/28/2006 11:11:28
57|PPP : LCP Start Fri, 4/28/2006 11:11:28
58|PPP : PPP Start Fri, 4/28/2006 11:11:28
59|PPP : PPP Disconnect Fri, 4/28/2006 11:11:27
60|PPP : PPP Idle Timeout Fri, 4/28/2006 11:11:27
61|PPP : LCP Start Fri, 4/28/2006 11:11:25
62|PPP : PPP Start Fri, 4/28/2006 11:11:25
63|PPP : PPP Disconnect Fri, 4/28/2006 11:11:25
64|PPP : PPP Idle Timeout Fri, 4/28/2006 11:11:25
65|PPP : LCP Start Fri, 4/28/2006 11:11:23
66|PPP : PPP Start Fri, 4/28/2006 11:11:23
67|PPP : PPP Disconnect Fri, 4/28/2006 11:11:23
68|PPP : PPP Idle Timeout Fri, 4/28/2006 11:11:23
69|PPP : CHAP Recv Challenge Fri, 4/28/2006 11:11:23
70|PPP : CHAP Start Fri, 4/28/2006 11:11:22
71|PPP : LCP OK Fri, 4/28/2006 11:11:22
72|PPP : LCP Start Fri, 4/28/2006 11:11:21
73|PPP : PPP Start Fri, 4/28/2006 11:11:21
74|PPP : PPP Disconnect Fri, 4/28/2006 11:11:21
75|PPP : PPP Idle Timeout Fri, 4/28/2006 11:11:21
76|PPP : LCP Start Fri, 4/28/2006 11:11:19
77|PPP : PPP Start Fri, 4/28/2006 11:11:19
78|PPP : CHAP Recv Challenge Fri, 4/28/2006 11:11:19
79|PPP : CHAP Start Fri, 4/28/2006 11:11:19
80|PPP : LCP OK Fri, 4/28/2006 11:11:19
81|PPP : LCP Start Fri, 4/28/2006 11:11:19
82|PPP : PPP Start Fri, 4/28/2006 11:11:19
83|PPP : PPP Disconnect Fri, 4/28/2006 11:11:19
84|PPP : PPP Idle Timeout Fri, 4/28/2006 11:11:19
85|PPP : LCP Start Fri, 4/28/2006 11:11:17
86|PPP : PPP Start Fri, 4/28/2006 11:11:17
87|PPP : PPP Disconnect Fri, 4/28/2006 11:11:17
88|PPP : PPP Idle Timeout Fri, 4/28/2006 11:11:17
89|PPP : LCP Start Fri, 4/28/2006 11:11:15
90|PPP : PPP Start Fri, 4/28/2006 11:11:15
91|PPP : PPP Disconnect Fri, 4/28/2006 11:11:15
92|PPP : PPP Idle Timeout Fri, 4/28/2006 11:11:15
93|PPP : LCP Start Fri, 4/28/2006 11:11:13
94|PPP : PPP Start Fri, 4/28/2006 11:11:13
95|PPP : PPP Disconnect Fri, 4/28/2006 11:11:13
96|PPP : PPP Idle Timeout Fri, 4/28/2006 11:11:13
97|PPP : PPP Connection OK Fri, 4/28/2006 06:56:12
98|PPP : IPCP OK Fri, 4/28/2006 06:56:12
99|PPP : IPCP Start Fri, 4/28/2006 06:56:12
100|PPP : CHAP OK Fri, 4/28/2006 06:56:12
101|PPP : CHAP Recv Challenge Fri, 4/28/2006 06:56:12
102|PPP : CHAP Start Fri, 4/28/2006 06:56:12
103|PPP : LCP OK Fri, 4/28/2006 06:56:12
104|PPP : LCP Start Fri, 4/28/2006 06:56:11
105|PPP : PPP Start Fri, 4/28/2006 06:56:11
106|PPP : PPP Disconnect Fri, 4/28/2006 06:56:11
107|PPP : LCP Start Fri, 4/28/2006 06:56:11
108|PPP : PPP Start Fri, 4/28/2006 06:56:11
109|PPP : PPP Idle Timeout Fri, 4/28/2006 06:56:11
110|PPP : PPP Disconnect Fri, 4/28/2006 06:56:09
111|PPP : PPP Idle Timeout Fri, 4/28/2006 06:56:09
112|PPP : LCP Start Fri, 4/28/2006 06:56:08
113|PPP : PPP Start Fri, 4/28/2006 06:56:08
114|PPP : PPP Disconnect Fri, 4/28/2006 06:56:07
115|PPP : PPP Idle Timeout Fri, 4/28/2006 06:56:07
116|PPP : LCP Start Fri, 4/28/2006 06:56:06
117|PPP : PPP Start Fri, 4/28/2006 06:56:06
118|PPP : CHAP Recv Challenge Fri, 4/28/2006 06:56:05
119|PPP : CHAP Start Fri, 4/28/2006 06:56:05
120|PPP : LCP OK Fri, 4/28/2006 06:56:05
121|PPP : LCP Start Fri, 4/28/2006 06:56:05
122|PPP : PPP Start Fri, 4/28/2006 06:56:05
123|PPP : PPP Disconnect Fri, 4/28/2006 06:56:05
124|PPP : PPP Idle Timeout Fri, 4/28/2006 06:56:05
125|PPP : LCP Start Fri, 4/28/2006 06:56:03
126|PPP : PPP Start Fri, 4/28/2006 06:56:03
127|PPP : PPP Disconnect Fri, 4/28/2006 06:56:03
