Anyone else getting a slow connection?
http://www.adslguide.org.uk/tools/speedchart.asp?id=57f2145810a661465f918cc2d92
For the past few days I've noticed websites etc loading alot slower, and then earlier today I was trying to stream a video and it was very jumpy. I decided to do a speed test and got those results. 300kbps on a 2meg connection?
I checked my usage to see if I'd gone over or something but I've only used 3gb altogether this month and less than a gig peak time.
Anyone else having problems?
Hi Sean,
Enter your phone number here and see if there are any reported problems with your exchange.
Also a BT Speed Test will also help to identify the source of the slow down.
Post back with the results. Smiley
You speeds sound a little slow this is the result from my 1meg
http://www.adslguide.org.uk/tools/speedchart.asp?id=1ce23c1010a662a78ab1a247e7d
Were you downloading anything else? i.e. Virus updating, downloads etc? This would affect your overal results. Also if your BB is shared you may find the other user hogging the bandwidth. If non of the above apply i'd raise a support ticket.
GL
Tim
