Another who want to cancell his Q jump max dsl
mjtuohy
Thank's Peter. I have started a technical support page and just put in my request when I got a pop up. Hope it works or my life could be a littl bit fraught.
thanks Martin
mjtuohy
Hi. I have 3 teens who use the internet as soon as they are home from school. Could I please cancell my Q jump for max dsl. Untill all has calmed down. Just thinking of the flak I will get if they can't connect. I did go to the help assistant but you only seem to get the main headings and if that is not what you want tuff. Needs a anything else heading.
You do have to raise a question to be removed from the list. Just follow any tech support route to get any pop-up help page and underneath is a link to raise a question.
Also see a thread on this very subject here.
