Am I still restricted?
AndyR
I forgot to shut down a torrent file and I went over the level 1 threshold for peak usage.
Now during the day off peak on well seeded items, I appear to be limited - is the level 1 restriction still on. I am in a new billing period.
I am getting the same speeds regardless of time of day.
Internet is not as quick as it has been prior to the level 1 being applied.
regards
Andrew
James
What speed do you get on HTTP? If you are still being applied on Level 1, then your HTTP would be limited to 2mbps.
AndyR
Speedtest done
regards
Andrew
James
Then you're not on Level 1 Management outside of peak hours.
