Actual IP Throughput
Hi James,
As you did with Deeney, can you look in to my speed test results below and do the necessary poking.
Best regards
Anthony
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 7150 kbps
DSL connection rate: 448 kbps(UP-STREAM) 8128 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 1693 kbps
James
I've actioned this now for you.
Many thanks for the speedy response James.
Best Regards
Anthony
