Activating MySQL for webspace to create a forum
I activated SQL for my webspace, it then came up with next page and said test connection using the details we've emailed u.
it's now about 10minutes since I done that and still no email, has anyone else had this problem when trying to activate sql.
also will this enable my domain which is hosting by f9 to also use the sql and cgi stuff.
I've also downloaded toastforums software to create my forum, and this can use SQL, can I import the data from toastforums into the database created when setup MySQL or not.
thanks
well an hour has now past and still no email from f9 advising me of what my username/password is for the sql database.
is there a problem with this?Huh
slev
Hi
Give the CS department a call on 0845 1400250 see if they can give you the details over the phone or resend the e-mail for you.
Kind Regards
Ian
would do but waiting time is over 10 minutes
Fixes: 69
woodviews,
Raise a support ticket and I'll reset your password and email the details again if you haven't resolved this one yet.
Drop me a PM once you've done this.
Kind Regards,
Plusnet Products Team
