Access to some sites but not others????
The kids have been complaining that they can't access myspace and bebo but access to some sites like the beeb is OK. We have a PC and a wireless network plus laptop and it is the same story on both - also took the laptop into work and via the guest wireless network all was fine to confirm it is not a PC issue.
Anybody else having similar issues?
What error message are you seeing when you try to access these site?
Try setting the below details on your router manually-
Primary DNS Server 212.159.13.49
Secondary DNS Server 212.159.13.50
After you've saved this, try disconnecting and then reconnecting your broadband after a few minutes.
James
We did have DNS issues earlier, which may have been related to this.
Thanks lestones - I will try the manual settings when I get home and report back - maybe in the meatime PN may have sorted it - never had this problem until now?
sam
Hi theaddamsfamily,
The DNS problems were resolved earlier this morning, so hopefully the problem will have been resolved for you.
