Access to Member Centre from my STB
Why can I not log in to the member centre when I use my Netgem I-Player?
Ianwild
Does it support Javascript and Cookies?
Yes. I have no problem logging on at Hotmail using this box.
Ianwild
Is the time set right?
What error do you get when you try to login?
What time? When I type in my username and password the screen goes blank and a little bar appears at the bottom of the screen, which reads - SSL3 Plusnet Technologies Sheffield - the screen then reverts to the login page.
Ianwild
I mean the time that the machine thinks it is - This needs to be right for the cookie!
Does that system work with secure http pages normally?
Regards,
Hotmail uses SSL to login, so the device must support that if he's able to login there.
I have no problem accessing other sites, which is why I mentioned Hotmail, where the same thing happens - SSL3 Redmond USA - appears, but then goes into the Hotmail inbox.
