Absolute Path & .htaccess
I've pulling my hair out trying to get .htaccess rollin, but with little success. Could anyone tell me what the absolute path to the main "htdocs" server is?
RE: Absolute Path & .htaccess
> Hi,
Hi Mark,
From our FAQ in the support section of the portal:
You can password protect your directories within your webspace by making 2 small text files.
Firstly which directory do you want to password protect?
It is not a good idea to password protect your main folder i.e: htdocs as people that get the login wrong will no doubt never return to your site.Open a new text document and enter the following...
AuthUserFile /share/isp/plusnet/www/uu/username/htdocs/path/.htpasswd
AuthName "Please Log On"
AuthType Basic
require valid-user
The part you need to change is the uu, username and the path replace the uu with the first two letters of your username, replace the username with your full username and replace the path with the name of the folder you wish to protect. If your username was for instance hotdog and you wanted to protect a folder called stuff the line would look like this...
AuthUserFile /share/isp/plusnet/www/ho/hotdog/htdocs/stuff/.htpasswd
Save the text file as htaccess.txt
Regards,
Robert
| Robert Kelly........................Unmetered & ADSL solutions
| Customer Support...........................for Home & Business
| PlusNet Technologies Ltd...............http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet ----------
> > Hi,
> Hi Mark,
> AuthType Basic
> require valid-user
> Regards,
> Robert
How do you delete a directory that you've password protected from your site using FTP. I've tried using CuteFTP and it says permission denied.
Daniel
> Daniel
Please see other thread.
Regards,
Robert
