ATM QoS Type
ATM QoS Type
Does anyone know why I cant use VBR?, I recently updated my Router Firmware but it caused connection issues for the wireless computer, I have since gone back to the old firmware but whenever I select VBR the router is unable to get an IP Address: 81.174.143.110, IP Subnet Mask or Default Gateway.
When I set it to UBR everything runs fine, I am then able to select VBR but it runs at slower than 56k speeds. I am only asking as I have noticed VBR being the recommended setting to have.
I am using a Zyxel 650HW-31 router.
Regards
Adam
MrToast
ATM QoS Type
Where is the recommendation for VBR?
Your router will need the correct connection type for the BT network. I presume (from your report) that its UBR, though I've never seen it discussed.
ATM QoS Type
it was mentioned over a year ago, only reason i brought it up is because I was sure I used to have it on VBR although I may be wrong. It is currently on UBR.
Here is the link http://portal.plus.net/central/forums/viewtopic.php?t=21506&highlight=vbr
Cheers
Adam
