ADSL uptime results
ADSL uptime results
I run several websites from an old server connected to my PlusNet ADSL connection, so I need the connection to be active as much as possible.
I use the supplied Solwise router (a SAR110), with a script running on the server to check connectivity every ten minutes and reboot the router in the event of a problem.
I can't tell the difference between router crashes and link downtime [1], but the results so far for 2004 are pretty good:
Wed Jan 7 12:20:12 GMT 2004 *** Link down. Router rebooted.
Thu Jan 8 04:20:21 GMT 2004 *** Link down. Router rebooted.
Thu Jan 8 04:30:16 GMT 2004 *** Link down. Router rebooted.
Thu Jan 8 08:00:22 GMT 2004 *** Link down. Router rebooted.
Fri Jan 16 04:20:23 GMT 2004 *** Link down. Router rebooted.
Mon Mar 1 12:10:23 GMT 2004 *** Link down. Router rebooted.
Thu Mar 4 04:10:23 GMT 2004 *** Link down. Router rebooted.
Thu Mar 4 04:20:22 GMT 2004 *** Link down. Router rebooted.
Sun Mar 21 12:10:23 GMT 2004 *** Link down. Router rebooted.
No downtime at all in February, link down on 8/1 and 4/3, and five other unknown disconnections. Not too shabby.
[1] or plus.net and google.com both failed to answer two consecutive pings!
Mark.
jberry
ADSL uptime results
Hi Mark,
Are you saying that the service is great with very few disconnections or are you having a problem? (I know which one I want it to be Smiley )
Regards,
ADSL uptime results
The former. I did say "pretty good"...
