ADSL Tests
ADSL Tests
Thought you guys would like to know this little gem of info.
You can check your distance from the exchange by dialing 17070 Select 3,1 and 2 you will then get dialled back with the info.
M. >:>
RE: ADSL Tests
This is not anything to make a decision on whether or not you can have ADSL. PlusNet and BT have a number of tests to perform on a line to ensure that the quality and signal strength is such that ADSL will be reliable.
Kind regards
Kevin
| Kevin Revill ............... Unmetered & ADSL solutions
| Customer Support .................. for Home & Business
| PlusNet Technologies Ltd. ....... @ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
RE: ADSL Tests
Kevin,
This wasn't meant to be the be all and end all of tests, I thought it would be a good starting point for your users to have a play with.
Glad to see you still have the communication skills taught to you by Matt Francis......
> Kind regards
> Kevin
fonejacker
RE: ADSL Tests
Hi Chaps,
Bit of a disclaimer:
This is a well published BT number, and while BT don't mind you using it too much they do ask that you do so out of peak hours. The system has a very low capacity and I believe it can be quite frustrating for the guys up the poles when they can't get a test line because loads of people are playing with this.
:bounce:
Best Wishes,
Ian
PlusNet Customer Support
