ADSL Router with 802.11g wireless connectivity
Hello all,
I was just wandering if anyone could recommend a good ADSL Router with 802.11g wireless connectivity.
Gary
I use the Belkin FD57632-4 and have found it to be a good and reliable router. It has four ethernet connections to the rear as well if you have other pc's without wireless capability that you want to network.
Mar
Pendragon
I'm using a Linksys WAG354G (flat brick Smiley ) modem/4 port router/wireless AP.
Upgraded to this from an old Binatone 4 port router just before I was Maxed.
It's very neat and tidy, just a small flat square box. Worked 'out of the box' and has been as solid as a rock from day one.
Should cost you about £60.00 from Dabs.com or less from ebuyer.
Regards, Colin.
carpangler
Yep - the WAG354G is pretty good as I've used that one for about 6 months now with not 1 single issue. The configuration is easy, the built in firewall straight forward/easy to configure.
The only thing I've noticed is the unit runs very warm to touch and the power supply gets very hot. Reading stuff on the net, this seems standard for this router and nothing to worry about.
jfrank
NetGear DG834GT
NetGear DG834GT
I have had the above for a year or so and it's been excellent.
It also has 108 mbit for local wireless connections and is compliant with all the new ADSL products etc.
It's range is great too.
Time to do some comparisons; thanks for the suggestions.
