ADSL Max
ADSL Max
I was upgraded this morning and my modem showed connected at 2.1Mbps but now it is showing as connected at 1.9Mbps
Is this normal?
Shall i expect this to change again?
Plusnet Staff
Plusnet Staff
ADSL Max
This is perfectly normal. The way the Max product works is that it will try and connect at the fastest rate your line will support whilst also trying to work out the stable rate.
This means that if you resync the modem at different times of the day it may sync at different rates because of small differences in line conditions and RF interference. For example, a resync in a evening may be at a lower rate to a morning because of things like street lights causing interference.
Plus the line may sync at too high a rate for it to stay stable as it works out what speed your line can support so it drops it rate down a touch.
ADSL Max
Ok, thank you for the information.
