ADSL MAX
ADSL MAX
Has anybody had a situation where they where downloading at 2mb pre adsl max and then as soon as it's been enabled their speed drops to 1mb.... I thought the purpose was to increase speed of the internet !!!.. Plus support have said that BT say that it's within acceptable limits !! Cry
Alecto
ADSL MAX
Is that your Max Stable Rate that is 1Mb? If you mean the results of a speed test, then everybody is slower at peak times as both Pn and BT have too many customers with fast lines.
James
Re: ADSL MAX
BT currently have you set to 1700kbps, and we have you set to the nearest 500kbps of that figure.
