ADSL Home Self-Install Installation Costs:
I just wanted to compare what my total cost for self-install adsl is compared to anyone else who may have got a better deal.
£70.50 - adsl line activation
£22.99 - monthly subscription
From www.dabs.com:
£26.44 - (total cost) 3 x Dynalink Adsl Filters
£51.69 - DabsValue Conexant PCI Adsl modem
Grant Total = £171.62 inc.VAT & Delivery.
I've gone for the cheapest ADSL modem available which i've heard should do nicely compared to a more expensive one that is double the price!
The question is, is an internal modem better than an external modem regarding ADSL - i'm concerned with USB bandwidth as PCI should have no problems like my current 56k modem?
RE: ADSL Home Self-Install Installation Costs:
I've just read a new review of this modem by a consumer via dabs.com. The person said that it was supplied with a cable which has a UK style plug on one end and not the RJ11 American style plug which means it won't fit into a filter unless the cable is changed but i'll have to see when it arrives.
Anyhow, where can i get a cheap RJ11-RJ11 cable from if needed?
I got a 10 metre RJ11-RJ11 cable from Videk, but they do all lengths...
http://www.videk.com/
If you order before 3pm, it should drop through your letterbox the next day.
Hope this helps
Ooops - should be http://www.videkonline.co.uk - sorry about that!
I would say that a PCI modem would have some advantages over a USB one, depending on the amount of USB devices you may need to ensure you do not use too much bandwidth or ampage. I use the USB Alcatel fish myself and generally have few USB problems, although they do rarely occur. You could consider a pwered hub if you did go for the USB option.
Chris
| Chris Rugen ............................... Unmetered & ADSL solutions
| Senior Technical Consultant ................... for Home & Business
| PlusNet Technologies Ltd .......................... http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet ----------
In my opinion, an internal PCI modem has less to go wrong in terms of using the PCI bus versus the USB bus.
I already have 6 USB devices 'hogging' the bus and I do get the occasional problem which is probably driver related, I would prefer to use the safer and more reliable PCI bus.
