ADSL Help Required
ADSL Help Required
Hi, I am using Windows 2000 and have a Dlink 200 ADSL modem. However everytime I switch my computer on, the two green lights,light up. But when I attempt to log on nothing happens. If I re-boot my machine (I also have to use the re-set swith to do this) I get my connection. Has anyone got any ideas please as it is driving me mad. (I have the latest drivers for my modem)
Alan
RE: ADSL Help Required
> Alan
Hi Alan,
To be honest it does sound like a drivers problem. It may not be a modem driver problem though, it could be a USB driver problem? Check your motherboard manufacturer's website, they may even have a revised BIOS that addresses your very issue.
Regards,
Mike
| Mike Grice.....................Unmetered & ADSL solutions
| Customer Support......................for Home & Business
| PlusNet Technologies Ltd..............http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
Thanks Mike,
Do you think a USB Hub self powered would help, I have just downloaded the latest drivers, so I will try that. Failing all of this. Do you think a router is the best option, and do you recomend any (or anyone reading this).
Alan
> > Alan
> Hi Alan,
> Regards,
> Mike
USB powered hubs tend to be much more stable than using your onboard USB controller in my experience -- it's down to you really.
ADSL routers tend to be the most reliable of all - however they can be a beast to set up. I've had hands-on experience with many, the D-Link 504, Zyxel Prestige 600 and the Alcatel Speedtouch Pro seem solid and not too hard to set up, in my opinion. Your mileage may vary. There's a good bunch of ADSL hardware reviews at www.adslguide.org.uk.
Regards,
Mike
I have an Alcatel ADSL Speedtouch Pro router. Its a doddle to set up initially. The headaches only start to come when you expand your home network and put in a dedicated firewall machine. I did manage to get it all working though, eventually.
I also have an Alcatel Speedtouch Pro, its a dawdle to setup for single user, can get a bit complicated if you are running a machine as a firewall/server with additional clients but it isnt to bad i have mine in this kind of setup under linux and win2k without a hitch.
I can highly reccomend it, plus it knocks about 10-20ms off ping times compared to a USB router, doesnt use up CPU like USB and you avoid VIA USB hassles if you have a VIA Mother....fu..sorry board Smiley
Ali
I moved from a VIA motherboard to a SiS ... much less hassle with AGP drivers... Wink
Regards,
Mike
