A quick question about Level 1 usage
Hi all,
I've just reached Level 1 usage or something like that and thats ok. I agree I've download a lot so far this month.
But I was just wondering...will my speeds go back to 2MB after midnight? or will they stay Level 1 (ie 512k) speeds till my next payment?
JonathanW
After mdnight, the shaping is lifted and your speeds will return to being as fast as possible.
thank you very much Smiley
aeroalfie
You don’t say which account you are on - just to clarify if you are on BB+ “your speeds will return to being as fast as possible.” only applies to certain protocols, HTTP, gaming, VoIP and a couple of others - files sharing is still shaped (meaning it will never be as fast as your line supports) like during the 16 hour peak time.
oh really?
Im on BB Premier and I meant NNTP protocol (USENET). So even after midnight my line is capped to Level 1?
aeroalfie
There are No restriction on your account during the 7-8 hour off peak time - unless you are on BB+ then certain protocols are shaped peak and off peak 24/7 .
JonathanW
No, on Premier everything will be as fast as possible after midnight. Its only on Plus that certain protocols are rate limited at all times of the day.
ahhhh gotcha. much appreciated.
:thumbs up:
