A couple of questions (please answer asap)
hi,
I am currently on the EasyStart 512kbps package at £24.99 but I want to downgrade (or upgrade?! confusing) to the 2mb premier at £21.99.
My questions are, is there a fee for this change?
What is the situation with payment? I have already paid £24.99 for this month
If I changed my package today, when would the changes come into effect?
Thanks in advance!
You will pay £14.99 as it is classed as a downgrade (less per month) and the changes will come into effect at your next billing date.
even though ive been paying more for a slower speed?Huh
You have been paying more for deferred activation and hardware which other customers had to pay for at that time up front, hence the difference.
when i tried to "downgrade" it said i would be charged a one off charge of £29.99 - not £14.99 which is bad enough! why is this?
LiamM
I believe it's £29.99 from Easystart down to Premier isn't it? £14.99 as it is a Downgrade, and £15 admin fee as it's Easystart.
Ben_Brown
If you choose to stay on your current speed it should be a £14.99 charge. If you choose to upgrade to the fastest speed your line can handle then the charge is £29.99.
If the upgrade then fails £14.99 is refunded.
