8Mb and the Training Period
thekitesociety
Ok I understand that there is a period of instability and so on and so forth whilst the system learns the new speed that can be supported.
But, would the portal show the new possibilities under connection settings? My reading of the fora and help seems a bit confused.
Some are saying that the speed is adjusted during the training period (which makes sense if you consider that without data at the possible rate then who is to tell if is any good or not) but others say nothing will change on the poral until AFTER the training period.
So - which is correct?
Mand
The portal settings are updated when we receive a delta report, this can take anything from 3-10 days.
In any case, I've made some small modifications to your account, so if you reconnect for me you should see some improvements. Smiley
thekitesociety
Thanks for that - I see that you have set the rate to 8000. No problems so far but I suspect that that would be a touch high - as the sync rate is 7616.
But only a few more days to go!
