7 Emails
7 Emails
Does anyone else have this problem? all my emails are duplicated 7 times surely this is using up valuable bandwidth.
Fixes: 69
7 Emails
Can you post the full headers? (although I'd advise you to remove your email address from them if you do).
Each email will have a unique message ID. If this is the same in all cases (along with the dates etc.) then this is more likely to do with your local setup. Do you get the same problem if checking your email using Webmail?
Kind Rgds,
Plusnet Products Team
Fixes: 8
7 Emails
The last time I had duplicated emails was because my outlook rules were processing emails multiple times.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
