56K Modem Restricted Dial-up Connections Speeds
I recently purchased an ADDON 56K V.92 PCI Internal Modem Card to replace a US Robotics 56K Voice/Fax External Modem which after several years use developed a fault. My Robotics modem connected almost constantly to Plusnet at 45333 bps but the new internal modem's normal highest connection speed to date is 33600 bps and it is frequently below this (lowest 21333). There was one exception on 29th December at 17:03 when it reached 45,333 bps
After checking and rechecking all the modem settings under my Windows 98SE operating system I am unable to improve on the 33600 bps speed. However, two speed tests with Plusnet showed that the card is capable of a much higher connection rates and that is confirmed by the one-off 29th December, occasion.
A look at my modem log shows that my dialup connection is receiving responses "Connect at V.34" so does this mean that the speed at which I can connect with my new card is being deliberately restricted? If so why? A listing of the modem log for the last 24 hours is shown below for reference.
MODEM LOG
01-04-2006 19:33:00.41 - Intel(R) 536EP Modem in use.
01-04-2006 19:33:00.41 - Modem type: Intel(R) 536EP Modem
01-04-2006 19:33:00.41 - Modem inf path: INTELC~1.INF
01-04-2006 19:33:00.41 - Modem inf section: Selah
01-04-2006 19:33:02.53 - 115200,N,8,1
01-04-2006 19:33:02.55 - 57600,N,8,1
01-04-2006 19:33:02.55 - Initializing modem.
01-04-2006 19:33:02.55 - Send: AT<cr>
01-04-2006 19:33:02.56 - Recv: AT<cr>
01-04-2006 19:33:02.71 - Recv: <cr><lf>OK<cr><lf>
01-04-2006 19:33:02.71 - Interpreted response: Ok
01-04-2006 19:33:02.71 - Send: AT&F E0 Q0 X4 S0=0 &D2 &C1 &S0 V1 W4<cr>
01-04-2006 19:33:02.74 - Recv: AT&F E0 Q0 X4 S0=0 &D2 &C1 &S0 V1 W4<cr>
01-04-2006 19:33:02.92 - Recv: <cr><lf>OK<cr><lf>
01-04-2006 19:33:02.92 - Interpreted response: Ok
01-04-2006 19:33:02.92 - Send: ATS7=60S30=10L3M1+ES=3,0,2;<cr>
01-04-2006 19:33:03.13 - Recv: <cr><lf>OK<cr><lf>
01-04-2006 19:33:03.13 - Interpreted response: Ok
01-04-2006 19:33:03.13 - Send: AT%C1+DS=3,0;+DS44=3,0;&K3X4<cr>
01-04-2006 19:33:03.31 - Recv: <cr><lf>OK<cr><lf>
01-04-2006 19:33:03.31 - Interpreted response: Ok
01-04-2006 19:33:03.31 - Dialing.
01-04-2006 19:33:03.31 - Send: ATDT###########<cr>
01-04-2006 19:33:28.72 - Recv: <cr><lf>+MCR: V34<cr><lf>
01-04-2006 19:33:28.72 - Interpreted response: Informative
01-04-2006 19:33:28.72 - Recv: <cr><lf>+MRR: 33600<cr><lf>
01-04-2006 19:33:28.72 - Recv: <cr><lf>+ER: LAPM<cr><lf>
01-04-2006 19:33:28.72 - Recv: <cr><lf>+DR: V42B<cr><lf>
01-04-2006 19:33:28.72 - Recv: <cr><lf>CONNECT 33600<cr><lf>
01-04-2006 19:33:28.72 - Interpreted response: Connect
01-04-2006 19:33:28.72 - Connection established at 33600bps.
01-04-2006 19:33:28.72 - Error-control on.
01-04-2006 19:33:28.72 - Data compression on.
01-04-2006 20:13:51.45 - Hanging up the modem.
01-04-2006 20:13:51.45 - Hardware hangup by lowering DTR.
01-04-2006 20:13:51.83 - Recv: <cr><lf>OK<cr><lf>
01-04-2006 20:13:51.83 - Interpreted response: Ok
01-04-2006 20:13:51.83 - Send: ATH<cr>
01-04-2006 20:13:52.21 - Recv: <cr><lf>OK<cr><lf>
01-04-2006 20:13:52.21 - Interpreted response: Ok
01-04-2006 20:13:52.21 - 57600,N,8,1
01-04-2006 20:13:52.21 - Session Statistics:
01-04-2006 20:13:52.21 - Reads : 995177 bytes
01-04-2006 20:13:52.21 - Writes: 246277 bytes
01-04-2006 20:13:52.21 - Intel(R) 536EP Modem closed.
01-04-2006 20:57:32.43 - Intel(R) 536EP Modem in use.
01-04-2006 20:57:32.43 - Modem type: Intel(R) 536EP Modem
01-04-2006 20:57:32.43 - Modem inf path: INTELC~1.INF
01-04-2006 20:57:32.43 - Modem inf section: Selah
01-04-2006 20:57:32.62 - 115200,N,8,1
01-04-2006 20:57:32.62 - 57600,N,8,1
01-04-2006 20:57:32.62 - Initializing modem.
01-04-2006 20:57:32.62 - Send: AT<cr>
01-04-2006 20:57:32.65 - Recv: AT<cr>
01-04-2006 20:57:32.80 - Recv: <cr><lf>OK<cr><lf>
01-04-2006 20:57:32.80 - Interpreted response: Ok
01-04-2006 20:57:32.80 - Send: AT&F E0 Q0 X4 S0=0 &D2 &C1 &S0 V1 W4<cr>
01-04-2006 20:57:32.83 - Recv: AT&F E0 Q0 X4 S0=0 &D2 &C1 &S0 V1 W4<cr>
01-04-2006 20:57:33.01 - Recv: <cr><lf>OK<cr><lf>
01-04-2006 20:57:33.01 - Interpreted response: Ok
01-04-2006 20:57:33.01 - Send: ATS7=60S30=10L3M1+ES=3,0,2;<cr>
01-04-2006 20:57:33.19 - Recv: <cr><lf>OK<cr><lf>
01-04-2006 20:57:33.19 - Interpreted response: Ok
01-04-2006 20:57:33.19 - Send: AT%C1+DS=3,0;+DS44=3,0;&K3X4<cr>
01-04-2006 20:57:33.37 - Recv: <cr><lf>OK<cr><lf>
01-04-2006 20:57:33.37 - Interpreted response: Ok
01-04-2006 20:57:33.37 - Dialing.
01-04-2006 20:57:33.37 - Send: ATDT###########<cr>
01-04-2006 20:57:36.14 - Hanging up the modem.
01-04-2006 20:57:36.14 - Send: <cr>
01-04-2006 20:57:36.33 - Recv: <cr><lf>NO CARRIER<cr><lf>
01-04-2006 20:57:36.33 - Interpreted response: No Carrier
01-04-2006 20:57:36.33 - Send: ATH<cr>
01-04-2006 20:57:36.71 - Recv: <cr><lf>OK<cr><lf>
01-04-2006 20:57:36.71 - Interpreted response: Ok
01-04-2006 20:57:36.71 - 57600,N,8,1
01-04-2006 20:57:36.71 - Session Statistics:
01-04-2006 20:57:36.71 - Reads : 84 bytes
01-04-2006 20:57:36.71 - Writes: 118 bytes
01-04-2006 20:57:36.71 - Intel(R) 536EP Modem closed.
01-04-2006 20:58:30.76 - Intel(R) 536EP Modem in use.
01-04-2006 20:58:30.76 - Modem type: Intel(R) 536EP Modem
01-04-2006 20:58:30.76 - Modem inf path: INTELC~1.INF
01-04-2006 20:58:30.76 - Modem inf section: Selah
01-04-2006 20:58:30.94 - 115200,N,8,1
01-04-2006 20:58:30.94 - 57600,N,8,1
01-04-2006 20:58:30.94 - Initializing modem.
01-04-2006 20:58:30.94 - Send: AT<cr>
01-04-2006 20:58:30.97 - Recv: AT<cr>
01-04-2006 20:58:31.12 - Recv: <cr><lf>OK<cr><lf>
01-04-2006 20:58:31.12 - Interpreted response: Ok
01-04-2006 20:58:31.12 - Send: AT&F E0 Q0 X4 S0=0 &D2 &C1 &S0 V1 W4<cr>
01-04-2006 20:58:31.15 - Recv: AT&F E0 Q0 X4 S0=0 &D2 &C1 &S0 V1 W4<cr>
01-04-2006 20:58:31.33 - Recv: <cr><lf>OK<cr><lf>
01-04-2006 20:58:31.33 - Interpreted response: Ok
01-04-2006 20:58:31.33 - Send: ATS7=60S30=10L3M1+ES=3,0,2;<cr>
01-04-2006 20:58:31.54 - Recv: <cr><lf>OK<cr><lf>
01-04-2006 20:58:31.54 - Interpreted response: Ok
01-04-2006 20:58:31.54 - Send: AT%C0+DS=0,0;+DS44=0,0;&K3X4<cr>
01-04-2006 20:58:31.72 - Recv: <cr><lf>OK<cr><lf>
01-04-2006 20:58:31.72 - Interpreted response: Ok
01-04-2006 20:58:31.72 - Dialing.
01-04-2006 20:58:31.72 - Send: ATDT###########<cr>
01-04-2006 20:58:57.12 - Recv: <cr><lf>+MCR: V34<cr><lf>
01-04-2006 20:58:57.12 - Interpreted response: Informative
01-04-2006 20:58:57.12 - Recv: <cr><lf>+MRR: 33600<cr><lf>
01-04-2006 20:58:57.12 - Recv: <cr><lf>+ER: LAPM<cr><lf>
01-04-2006 20:58:57.12 - Recv: <cr><lf>+DR: NONE<cr><lf>
01-04-2006 20:58:57.12 - Recv: <cr><lf>CONNECT 31200<cr><lf>
01-04-2006 20:58:57.12 - Interpreted response: Connect
01-04-2006 20:58:57.12 - Connection established at 31200bps.
01-04-2006 20:58:57.12 - Error-control on.
01-04-2006 20:58:57.12 - Data compression off or unknown.
01-04-2006 20:59:12.17 - Hanging up the modem.
01-04-2006 20:59:12.17 - Hardware hangup by lowering DTR.
01-04-2006 20:59:12.55 - Recv: <cr><lf>OK<cr><lf>
01-04-2006 20:59:12.55 - Interpreted response: Ok
01-04-2006 20:59:12.55 - Send: ATH<cr>
01-04-2006 20:59:12.93 - Recv: <cr><lf>OK<cr><lf>
01-04-2006 20:59:12.93 - Interpreted response: Ok
01-04-2006 20:59:12.93 - 57600,N,8,1
01-04-2006 20:59:12.93 - Session Statistics:
01-04-2006 20:59:12.93 - Reads : 613 bytes
01-04-2006 20:59:12.93 - Writes: 663 bytes
01-04-2006 20:59:12.93 - Intel(R) 536EP Modem closed.
01-05-2006 10:45:23.52 - Intel(R) 536EP Modem in use.
01-05-2006 10:45:23.52 - Modem type: Intel(R) 536EP Modem
01-05-2006 10:45:23.52 - Modem inf path: INTELC~1.INF
01-05-2006 10:45:23.52 - Modem inf section: Selah
01-05-2006 10:45:25.46 - 115200,N,8,1
01-05-2006 10:45:25.46 - 57600,N,8,1
01-05-2006 10:45:25.46 - Initializing modem.
01-05-2006 10:45:25.46 - Send: AT<cr>
01-05-2006 10:45:25.49 - Recv: AT<cr>
01-05-2006 10:45:25.64 - Recv: <cr><lf>OK<cr><lf>
01-05-2006 10:45:25.64 - Interpreted response: Ok
01-05-2006 10:45:25.64 - Send: AT&F E0 Q0 X4 S0=0 &D2 &C1 &S0 V1 W4<cr>
01-05-2006 10:45:25.67 - Recv: AT&F E0 Q0 X4 S0=0 &D2 &C1 &S0 V1 W4<cr>
01-05-2006 10:45:25.85 - Recv: <cr><lf>OK<cr><lf>
01-05-2006 10:45:25.85 - Interpreted response: Ok
01-05-2006 10:45:25.85 - Send: ATS7=60S30=10L3M1+ES=3,0,2;<cr>
01-05-2006 10:45:26.06 - Recv: <cr><lf>OK<cr><lf>
01-05-2006 10:45:26.06 - Interpreted response: Ok
01-05-2006 10:45:26.06 - Send: AT%C0+DS=0,0;+DS44=0,0;&K4X4<cr>
01-05-2006 10:45:26.24 - Recv: <cr><lf>OK<cr><lf>
01-05-2006 10:45:26.24 - Interpreted response: Ok
01-05-2006 10:45:26.24 - Dialing.
01-05-2006 10:45:26.24 - Send: ATDT###########<cr>
01-05-2006 10:45:51.65 - Recv: <cr><lf>+MCR: V34<cr><lf>
01-05-2006 10:45:51.65 - Interpreted response: Informative
01-05-2006 10:45:51.65 - Recv: <cr><lf>+MRR: 33600<cr><lf>
01-05-2006 10:45:51.65 - Recv: <cr><lf>+ER: LAPM<cr><lf>
01-05-2006 10:45:51.65 - Recv: <cr><lf>+DR: NONE<cr><lf>
01-05-2006 10:45:51.65 - Recv: <cr><lf>CONNECT 31200<cr><lf>
01-05-2006 10:45:51.65 - Interpreted response: Connect
01-05-2006 10:45:51.65 - Connection established at 31200bps.
01-05-2006 10:45:51.65 - Error-control on.
01-05-2006 10:45:51.65 - Data compression off or unknown.
01-05-2006 11:12:18.69 - Hanging up the modem.
01-05-2006 11:12:18.69 - Hardware hangup by lowering DTR.
01-05-2006 11:12:19.07 - Recv: <cr><lf>OK<cr><lf>
01-05-2006 11:12:19.07 - Interpreted response: Ok
01-05-2006 11:12:19.07 - Send: ATH<cr>
01-05-2006 11:12:19.45 - Recv: <cr><lf>OK<cr><lf>
01-05-2006 11:12:19.45 - Interpreted response: Ok
01-05-2006 11:12:19.45 - 57600,N,8,1
01-05-2006 11:12:19.45 - Session Statistics:
01-05-2006 11:12:19.45 - Reads : 1517054 bytes
01-05-2006 11:12:19.45 - Writes: 302541 bytes
01-05-2006 11:12:19.45 - Intel(R) 536EP Modem closed.
you don't happen to have ADSL on the same line do you?
No, it isn't that. I have an exclusive BT line. But in any case that would not explain why the two modems attain different connection speeds on the same line. My old Robotics modem still works but has an intermitent fault which makes it unreliable hence the replacement. However, I have reinstalled the old modem to test the line and it still obtains 45333 bps so the problem seems to be specific to the new card.
___oDiN__
ive found its usually down to drivers
the intel drivers are renound for doing just that often the ones that come with the modem are fine then updated via windows update and offer slower connection speeds but to be honest i doubt you will actually get slower speeds ( if thats possible on dial up) but have a look at see what driver version you are on and wether its a new or old and try a different one or join the broadband world if avialable to you my refferal of course... Cheesy Cheesy Cheesy Cheesy Cheesy
odinsrealm,
I took your advice and downloaded the latest drivers from Intel but unfortunately they have made no difference to the connection speed.
I think I will return the card to the retailer and ask them to demonstrate its "56k" capabilities or give me my money back. At least that way I may be able to eliminate any capping of connection speeds by Plusnet. After all, what better way is there for Plusnet to drive subscribers to broadband, But that's probably unnecessarily cynical! And anyway, broadband speeds seem to be an equal source of frustration according to other threads.
Thanks for suggestion.
