53.4kbps on LLU 3600
Well this just gets better!!!
Dialup speeds!! absolute joke!!
Plusnet do not provide a service that is "fit for purpose"
Have you tried the BT speedtest? That will tell you if the problem lies with BT or PN.
Also, your sync, SNR, Attenuation/etc would be useful as well.
Hi I tried that but it would not let me connect using
speedtest@speedtest_domain
Login fails
rz2k7
Hi
AFAIK if you're on Tiscali LLU then the Bt speed test won't work as it's just for BT lines.
Not sure if there is a similar speed test for LLU though.
For LLU, you need to use:
Username: testing@dslconnect.co.uk
Password: testing
and then try and browse to http://www.dslconnect.co.uk
