30 minutes of down time
What happened for the last 30 minutes?
No service whatsoever.
All the phone lines for customer service, faults, service status were engaged.
No update on the service status.
I'm glad I've got my mac and will be leaving soon.
And all this just a day after the vision for 2007 email was sent out.
Fixes: 5
There was a Service Status about this a while ago. Also an update here and here.
Phil
James
It was an unfortunate and unavoidable issue caused by the earlier BT outage. This leads to our hitting session limits on the other 3 Gateways, causing authentication issues, hence the problem that you were seeing.
The issue is still being worked on as we speak.
graingerjjb
the network seems to be going up and down like a yo-yo at the moment -do we know when it will calm down again ?
James
PTN-AG1 has been rebooted a couple of times as part of the problem diagnosis.
Once further information is available, the status message will be updated.
James
And should now be fixed.
Status posting will be made shortly.
rslsys
Still unable to re-connect until 10 minutes ago though . . .
Phone numbers still engaged too...
Plusnet Staff
Plusnet Staff
The call stats are available on the portal here:
http://www.plus.net/supportpages.html?a=212
Looks like the number of calls has reduced back to normal levels now.
The network is still quite out of balance from the problems earlier and three of the gateways have been pretty much full so with the round robin authentication from BT's side it may have taken a few connection attempts to get back online if you keep hitting the these gateways.
Hahahaha. The call stats - useful, or rather useless, as ever.
I notice the graph never went over 36 calls.
Does this mean that the PlusNet phone system can never handle more than 36 calls?
Throughout the period everything was just engaged.
PlusNet were entirely out of touch with their users via telephone for at least 1 hour - even the pre-recorded status line was unusable.
After 2006, I would have expected some sort of resiliency in the event of an outage -- but oh no.
I'm glad I don't run a business via PN.
Plusnet Staff
Plusnet Staff
I'll certainly make sure that this is flagged up, at the very least the service status line should have been working at that's very concerning.
So how many calls can the call centre system and the service status line handle?
