30:1 contension
30:1 contension
Hi just a quick question... if BT have no port capacity problems on the Home IPStream (50:1 contention) product range @ my exchange .. How are you managing to put me on 30:1 contentionHuhHuh?.. Because the only packages i saw there where the Office IPstream @ 20:1 contention and the Home IPStream 50:1 i mentioned.. So its puzzling me
plusnet's definition of contention
is designed to be misleading.
30:1 contension
Just means there offering more bandwidth per user on plusnets end
30:1 contension
i am supposed to be on 30:1 but where on this site can you find anything to tell me that......... :?
Is there any way of checking using software test or looking it up somewhere on members centre......... Wink
Just wondering... :roll:
30:1 contension
Quote from broadband premier description
'Broadband Premier is based on a PlusNet network contention of 30:1, giving you a top quality broadband service day and night. You'll get high-speeds even at busy times, whether you're surfing and emailing, downloading large files or connecting multiple PCs on your home network'.
30:1 contension
ahh i forgot about that bit, thanks
